Popsocket and wireless charging
mthom5
Active member
Feb 16, 2013
35
Anyone have any luck charging with a popsocket? If so what charger are you using? It won't work with my old Samsung charger I got when I bought my s7 a couple years ago.
Two of the materials you can get a PopSocket in are aluminum and metallic diamond - and that would prevent wireless charging. With any wireless charger. Wood may or may not be too thick to allow wireless charging. (They should have thought of that and made a thin plastic one.)
no luck for me as of yet and I have the new Samsung wireless convertible charging pad. the pop socket goes directly over the ideal spot on the phone which is where the charger needs to be. I love my pop socket so thinking of either forgoing the wireless charger or just taking the socket off at night when I want to charge it
My wife has a pop socket on her iPhone, she enjoys it as she takes alot of selfies. I don't have use for one but I believe it's one of those things that if you get one you're sacrificing other stuff to have it.
Technirere221
