R recDNA Well-known member Jun 29, 2011 8,784 161 63 Dec 31, 2016 #1 Which type portable power source is safe with v20? Anybody got one? Hoping to not spend a fortune.
Rukbat Retired Moderator Feb 12, 2012 44,531 46 48 Dec 31, 2016 #2 Any 5 Volt power source is "safe". If you're looking for a powerbank, try [Review] - Coocheer® 7500mAh Rugged Water Resistant Power Bank. You could probably run it over with a truck - and run the truck's tire flat.
R recDNA Well-known member Jun 29, 2011 8,784 161 63 Dec 31, 2016 #3 Any specific for usb c? I thought we used 9 volts?
frope01 Well-known member Jul 26, 2013 366 0 0 Dec 31, 2016 #4 I got the small and light, Anker 10000 mAh with quickcharge 3.0 for my Note 7. Figured I may as well try it with my V20. Works great. Anker PowerCore 10000 with Quick Charge 3.0, 10000mAh Power Pack Portable Charger with Qualcomm Quick Charge 3.0, for Samsung, iPhone, iPad and more https://www.amazon.com/dp/B01CZV9FU...ag=hawk-future-20&ascsubtag=UUacUvbUpU5627371
J joediver Well-known member Apr 4, 2011 79 3 0 Jan 1, 2017 #5 I have the Anker PowerCore 10000mAh with QC 3.0 also.
P Purple Spy Active member Sep 21, 2016 26 0 0 Jan 1, 2017 #6 The 20k anker is still easily pocketable unless you're a super skinny jean fanatic, it gets my recommendation, had it for a few months now
