possible fix of data drop
raidil
Active member
Feb 23, 2011
43
I I been getting pissed about my 3g 4 g dropping in search settings and found a setting for from engine battery life which drops your data. stock it is 45 minutes then turn off your data so I set mine to always on. I changed my peak time to represent the time I don't use data. I have not lost 3g 4 g since i change the settings. You can find these sett under the battery manager
It turns off the radios after some inactivity to save battery, it doesn't "drop" your data, it's just shutting off your radios. The data dropping is something completely different.
pututo
