Possible Signal Issues...??
lyingfromyou
746
45
28
I Have Had Trouble Sending And Recieving Text Messages Almost All Day... I Am Running A Rooted NS4G And No Matter What ROM I Flash (These Are Rom's I Have Not Had Issues With Before) I Have The Same Issue! It Fails To Send My Text Messages And When I Do Recieve Them They Come In All At Once. Now It Is Telling Me I Have Lost Data Connectivity Due To International Roaming. I Have Updated The PRL And Still The Same Thing! Is Anyone Else Having This Issue??
I have a friend who is having the same problem, but she said it didn't start until she applied an OTA update sent out by Sprint.
Same phone: Nexus S 4G. She lost root when she applied the update, so I'm not sure if re-rooting will actually help.
I Think Sprint Was Just Having Some Local Troubles Or Upgrading Or Something, Everything Turned Out Fine The Next Day! :)
Sorry Mods! You May Delete This Thread if Need be...
I was having really bad data speeds along with marginal signal strength after I updated to prl60685 in the beginning of March . I used to have good data speeds before that. Then I noticed the that a new prl 60686 was just released. I did update and I must say wow.. My 3G. data is back up to 2+ MB per second again and the signal strength after in my bedroom. Is full bars.. I never seen that before. Usually. 2-3 bars . And 4G 13-15MB per second. And best of all my battery life in 3G
has improved alot. I recommend updating your prl. Hope this helps
Wish I could get that lucky! What phone are you using?
Mint Auto Trades
