- Jun 23, 2011
- 52
- 1
- 0
So,
I contacted HTC about the youtube sound issue a bunch of people have been having with it popping and whatnot. It seems to have fixed it for me. I'm still testing, but would appreciate someone else giving it a try.
The dudes English is poor, but hes basically saying wipe the cache partition after disabling fast boot.
//edit// disregard, issue remains. the reset took youtube out of high quality on mobile mode, which appears to lessen the problem.
Make sure the potion for fast boot it is not enable, to check this go to menu > settings > Battery > Fast Boot, make sure this option is disable, that it is uncheck.
You will need to have the phone in the Recovery screen, to get there, with the device powered off press and hold the Volume Down then briefly press the Power button, you will see the android logo and wait until you see a menu > Navigate to ?Recovery? using volume buttons > then press power to select > wait until you see an icon of a phone with an exclamation mark and a triangle, as soon as you see it, press and hold volume up then press the power button > Navigate to ?Wipe Cache? > Navigate to ?Reboot Phone?
