Post OTA Calendar problems
XXI
192
after the OTA I have all my Calenders checked but only some appear on my google calender on my TB. Anyone else have this problem?????????
Did you check in Settings > Accounts & Sync to be sure they are all set to sync?
Just an idea, but go into Settings > Applications > Manage applications > All tab > I have both Calendar and Calendar Storage... I think you should open both and click the Clear data button on both... then go back into Accounts & sync and sync all.
I've used the "Clear Data" button on "Calendar Storage" app a couple of times when the calendar entries seem to have gotten out of sync. No ill effect other than the next sync takes longer because it has to download all of the calendar entries again. I'm not sure what clearing the data for the "Calendar" would do since I don't use the stock calendar, but I'm guessing it would just reset the settings unique to the stock calendar app.
Reactions: fatboy97
Those were the two apps I thought might have the information that was causing the issue... but I'm sure you are right... clear the Calendar Storage first... see what happens... if it fixes things stop there... if not try the other.
I've never had the issue, but it was just guess work on my part... thanks for the info RichardClark.
metafortune69
