Post your 4G/3G speed!
Beezzy
613
27
Use the Speed Test app from the Android market, works much faster than the web version
Next time, turn off the GPS, I got faster speeds when I turned it off. I was getting 3.4 before and 4.1 after.
Salem, OR:
3G: 2194/858
4G: 1673/993
I don't even bother using it. I mean, even if it was faster or if I could actually get good enough reception to use it reliably, I want more than 6 hours of battery life.
Here is my 3G speed.. I won't be able to test 4G until I go back home to Chicago in a few weeks :(
i find the reading to be considerably different when using speed test / cnet bandwidth meter. i might try a few other places now for comparison
I've found the variation from test to test, and site to site, to be incredibly variable. To get any meaningful results is going to require averaging a bunch of tests. And any test is location dependent, so ideally you'd want to repeat them from multiple locations.
Anyway, here are 10 tests each for 3G and 4G, using 2 different test services. I've got full bars on the 3G signal, and only 1 on 4G. Hopefully 4G will get faster as the signal gets stronger. All tests were from the same location, within a span of about 30 minutes.
Code:
	mobile.speedtest	        	speedtest.net Android app
Test #	[COLOR="Blue"]3G down[/COLOR]		[COLOR="Red"]4G down[/COLOR]		[COLOR="Blue"]3G down[/COLOR]	3G up		[COLOR="Red"]4G down[/COLOR]	4G up
1	928		816		766	737		1408	1041
2	722		1489		1372	674		2400	918
3	688		1381		1312	674		2051	1011
4	543		1283		652	537		1362	1035
5	1012		1282		783	643		1401	797
6	793		1275		739	697		787	855
7	1299		1276		908	637		2111	804
8	1168		1452		1116	697		1740	960
9	1451		1418		937	692		1489	850
10	1396		1404		841	715		2237	874
Sum	10000		13076		9426	6703		16986	9145
Avg	[COLOR="Blue"]1000		[/COLOR][COLOR="Red"]1307.6	[/COLOR]	[COLOR="Blue"]942.6[/COLOR]	670.3		[COLOR="Red"]1698.6[/COLOR]	914.5
So on the mobile.speedtest site, 4G was, on average 31% faster. On the speedtest.net app, it was 80% faster. How representative is this? No idea.
Oh, I read somewhere that speeds are slower if you have the GPS radio turned on, which I did. I also had BT turned on. Maybe next week I'll try again with only the 3G and 4G radios on.
kelkongko0510
