Potential workaround for the battery drain issue
daihard2008
324
I was browsing through an XDA-Developers forum where someone said he had his battery drain issue drastically improved by switching to the KitKat radio firmware. He said he had experienced 3+ %/hour drain with the latest Lollipop radio but it was now less than 1%/hour idle after switching to the KitKat radio.
I didn't think I was experiencing a drastic battery drain but decided to give that method a try. Wow... he may be right. I don't have the hard numbers yet, but it sure looks like my battery is lasting much longer now. For those of you who are having a bad battery life using Lollipop, this may be worth a try.
daihard2008
324
Any link as to how to do this or to the XDA forum? I searched there but didn't find it.
The discussion started here.
[ROM] [Lollipop 5.0.0] [HAMMERHEAD] Cataclys… - Pg. 949 | Google Nexus 5 | XDA Forums
The radio files for the Nexus 5 can be found here.
[MODEM] [EFS] Nexus 5 Flashable Modems and E… | Google Nexus 5 | XDA Forums
I have the firmware file that came with the KitKat factory image, so I just flashed it using the fastboot command as follows:
Code:
fastboot flash radio radio-hammerhead-m8974a-2.0.50.1.16.img
