- Dec 19, 2015
- 11
- 0
- 0
Can someone point me in the right direction, need a fast charging power bank for my note 10 plus. Thanks in advanced.
Another consideration is how fast can the power bank be charged especially the larger ones. I have one that allows itself to be rapid charged and has more than one charging input.There are really too many to mention. How big are you looking for, both in physical size and mAh? Does it have to be USB C? Does it need wireless charging? What kind of budget are you looking at? Aukey, Anker, Samsung, and many others make good ones, but a little more info would help narrow it down a little.
I don't know what the current prices are but Ravpower makes them with rapid recharge. I have one in 28,000mAhWow! I haven't thought about that. I need something that's about 20000mah. Budget wise, under $40 would be ideal. I definitely need fast charging on the power bank as well as rapid charging on phones. Couldn't care less how big it is. Going to use for emergency situations only. Thanks.
I have that one also. It has it good points and it's bad points over conventional wired models.I bought this one and totally love it. No cords except to charge the unit. And it's a Samsung.
https://www.amazon.com/Samsung-Port...ag=hawk-future-20&ascsubtag=UUacUvbUpU6770333
