Power Button Blues
Keith Morris1
Upgraded from an M7 and the phone is a belter in every sense. However the power button moving from top left to the middle right-hand edge is causing me problems in as much as I keep turning it on/off inadvertently!! Aside from learning to pick it up off-centre so fingers don't hit the buttons, any idea's how to cure the problem please?
Unfortunately you can't move the button, but triple tapping the screen will wake the phone up. That way you can use it without having to pick it up.
In addition to the double tap, I also put the "Screen Off" button in the navigation tray so I never really have to touch the power button.
How long have you had it? I adjusted it to it pretty well after 3 or so days. I rarely hit the wrong button anymore.
I've had it a week now and It's just a natural thing to pick it up centrally, which of course hits the power button! I will have to try and find a case that has "cut -outs" for the buttons, which might make them a little harder to press.
sportzfyapp
