Power Button Ends Call on IHO CM7 on Optimus V. Way to disable?
mzxeternal
Active member
Mar 11, 2011
28
Hi, I'm hoping that somebody may have a solution for this because I can't find a clear answer anywhere. I'm running IHO CM7 on my Optimus V, and ever since I installed it the Power Button now ends phone calls instead of simply turning off the screen. It's driving me nuts! I tried going into Setting > Accessibility and checking and unchecking the option there and it doesn't seem to have any effect.
Is there any hack, fix or am I missing an option in CM7 somewhere? Any input or advice would be appreciated!
Re: Power Button Ends Call on IHO CM7 on Optimus V. Way to disabl
And sorry in advance if this issue has been discussed before. I found people asking the same question, but no answers for it.
It's easy yet tricky.
Go into settings, accessibility.
Now this will give you a prompt saying none ware found, it's wrong, The prompt is regarding certain extras, the feature we want however is there. If you hit Okay it will take you to the Market and try and get you to download some things you don't need.
Hit cancel.
Now uncheck "power button ends call"
Hit cancel.
Thank you for the tip LeslieAnn, and thank you even more for all the work you do with the Harmonia roms. I was a big fan of 1, and looking forward to trying 2 when I have a chance. Unfortunately the trick didn't work for me, I tried it a couple of times with no luck. I also tried allowing the install to go through and trying it then without luck.
[App] ButtonRemapper - Beta v0.2.4 (New Galaxy S version added) - xda-developers
i use this app to change the power button from' end call' to' screen off' and it does what youre looking for .. simple as that
Well I have it installed, but I'm not sure which setting to change, I can see there's 2 power buttons listed. I don't want to disable the button completely if I get it wrong. Could you tell me which one I should change to do it?
Thanks for all your help!
Spare parts will also work I suppose. As i helped my cousin with it on his Huawei Ascend.
Thanks for all the tips, but after some issues with my phone (including my battery deciding to explode?!, the phone survived it thankfully), I decided to switch over to Leslie's Harmonia2 rom, which is working brilliantly and doesn't have the same problem!
Vector
