power control widget's on notification bar
hyruu
74
4
I have looked everywhere I may be blind but is adding power control widgets to the notification drop down possible? Kinda like the Samsung Epic 4G.
As for as I know, it's on gingerbread roms, and Nameless is supposedly comin out with an update next week with it for 2.2.
Power control widget plus on the market can put Widgets in the notification bar also.
If I could figure out which files that them settings live in can I swipe the files out of their Framework and put it in the Framework I am currently using?
Not necessarily.
That is a tricky game, because the file you swap, may have controls for something else. Especially on a rom like Nameless, which has a lot of tweaks.
