Power Management and CDMA, need widget
h3seaking
18
I am led to believe power management programs like Power Manager, and Ultimate Juice don't work with Verizon android phones. So, I am looking for ONE SMALL widget or program that will allow me to switch on and off the data, airplane, wifi modes and voice modes. Having a widget for each uses too much real estate.
Any advice?
There's a built in power control widget you can use for most of these functions. There's also individual widgets you can add from the add widget selection panel under the settings drop down. You can quickly access airplane mode by holding down the power button for 2 seconds.
What features are controlled by the power control widget?
Cory, silly question here. I placed the power control widget on one of my home screens, but I can't find anything that tells me what the five different symbols each control? I'm new to the Android system. It looks the like the first two are wifi and bluetooth, and the last is brightness, but what do the third and fourth buttons control?
1. wifi
2. bluetooth
3. gps
4. something to do with sync
5. brightness
you can also go to:
menu >> add >> widgets >> settings
to add the individual small widgets that you need
Shortcut for Power off?
Thanks for the previous answers. Is there also a shortcut of some sort that can be used to "power off," rather than having to hold down the top button? I thought I saw somewhere on the forum that one could create an icon for that on the homepage.
