Power saving changes settings
  • Start date Start date
A
Android Central Question
My P30 Pro seems to be changing notification and other settings when it enters power saving mode.
I understand while it is in power saving mode that certain things are turned off, etc but after charging these settings don't reset. I will have to go reset my auto brightness, some apps suddenly don't display notifications, etc, etc.
Any ideas on what is causing this??
I don't know exactly what percentage it changes back on. It does appear to turn off as when you go into the settings it is marked off.
Could it be the updating the phone does every night? Somehow resets apps?
Ive had to reset notifications for Gmail, FB, Instagram. Notification dots dont go away. Auto brightness always turns itself on. Ill open an app which says i have 0 notifications and itll say 6 when i get in there...only for them to be old.
Power saving saves power by not allowing the apps on the list to run unless you run them manually - so of course you won't get notifications. Take the apps you want notifications from off the list (disable power saving for them).
gitkitten
