Power saving mode issue
Tyler_13
3
Hello, when I put my s5 into ultra power saving mode it will start to restart itself lots and doesn't like to disable when I try to
sent from my galaxy s5 using tapatalk.
I tried powersaving mode for a short time after I got the phone. Seemed to slow things down too much (I didn't know about unchecking the processer speed setting when I tried it), but I never had the reset problem. Are you sure the phone's not overheating?
Also, I found as I tweaked the phone that I don't really need power saving mode. I might if I was going on a trip or something, but for daily use, I get more than enough battery out of the device to not have to use powersaving.
In standard power saver phone works good but in ultra power saving mode it will keep restarting itself for no reason. I don't use it a lot but here and there when battery is low and can't get to a charger but it's useless cause the restarting kills it quicker
Hmmm. Don't know how to help you with that one. I have limited experience on a lot of this stuff.
Usually this is caused by Xposed with the Wanam Xposed Module enabled. Try disabling Wanam Xposed, then reboot before going into Ultra Power Savings Mode. Good luck!!
leodas0705
