Power Saving Mode Without Samsung Keyboard
kdklein
Active member
Nov 12, 2012
29
I'm not sure if I had this issue on my old note 7 or not, guess I didn't have it long enough. I'm using swiftkey and when I put my phone into power saving mode at a lower resolution they keyboard is not being reduced in size so I can only see the left 2/3 of the keyboard and can't type.
Anyone else run into this?
Nope, it happened on the 'old' Note as well. I haven't tried with other keyboards so I don't know if it's a SwiftKey issue or that would happen with all 3rd party keyboards, though.
So I didn't try restarting my phone before posting that. I restarted it and now it works. Should have tried that first.
Oh..ok! So, can you go out of Battery Saving mode and then back in (without rebooting)? Does the keyboard show up fine both times? I wonder if using a 3rd party keyboard (or Swiftkey, still don't know if it's a SK thing) requires a reboot every time you change resolutions.
TOOLS
