Power Share POWER SHARE
Re: Power Share POWER SHARE
Its here
It wont let me turn it on unless I'm over 30 percent ..understandable lol
At thirty percent it doesn't buy you much because it would equalize at 15 percent assuming you gave away half your charge.
I would use that feature sparingly anyway because over time it will diminish your battery capacity if used frequently.
You think it would diminish the battery, if used frequently?
It works, but I can't get it to charge my Gear S2 because it won't lie flat to the phone. I guess it's more for the pods. Neat feature, but I honestly doubt I'll use it much.
I could be wrong about this, but I believe it's only compatible with the Gear S3 and above. I say that because this looks to be the same technology as the charger pad 2018 (which charges either a phone or a watch), and that charger explicitly states it's compatible with the Gear S3 and above.
Well you're discharging the battery so however many charge cycles that adds up to. Not a concern unless you were charging someone's phone frequently. Remember it will only charge till it reaches about 1/2 of what starts out with or the low cutoff point.
Something to test out ,I'm curious lol
Clout
