Power Supply for international travel for NC
KimPossible
7
I've looked through the teardown at Novaports and haven't found any info about the power supply. Is it possible to use a different USB wallwart with the NC? I am about to do some international travel and really want to be able to take my NC with me. But I hate using step-down transformers.
Any body figured this one out?
mucho gracias!
Kim
The Nook Color charger is 110/220v. I just traveled to Europe and used the regular charger with no issues.
Yep...you just need a plug adapter, which you can pick up for a few bucks down at at the Walmart.
Make sure you just get an adapter...you don't need a power converter.
Seachild80
