Print from my Note 4?
indysteve9
184
I have an HP 3030 laser printer with a USB port. If I use a bluetooth dongle plugged into that port can I pair it to my Note 4 and print from my Note 4?
Re: Print from my Note 4
If your printer is on a network then install Google Cloud Print. If not, then using USB cable, connect your phone to your computer and your computer will see your phone as a drive. You should then be able to print your document using local printer.
ameliadinkins
