• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues please let us know in this thread!
Problem at the Sound on the Samsung S4 mobile
A
AC Question
Hi
I have aproblem with my S4.
No sound at all. Not in the speaker, Not in the Ear phones and not at the Ear of the mobile.
I think it is since i update the HW and Fremware.
How to Do a hard Reset ? what can be the problem. which part is it ? where is the Audio processor on the S4 board.
Does anyone has a boars parts description ?
Thanks
yoram
[emal removed by Moderator]
note3owner
25
Sometimes merely a reboot works. There may have been a problem with the sound card failing to initialize.
If that doesn't help, and if you are still under warranty, go to samsung.
Else
Try a factory reset
Backup all your contacts, pictures and important data.
Get into recovery mode (check it on Google how to, its on a per phone basis, but usually pressing all physical buttons works)
Then wipe data in recovery mode.
