problem downloading widgets and skins from HTC
toll
Active member
Feb 14, 2010
37
"unable to download widgets. try again later" is all i get when trying on a custom rom (uber BAMF, gingeritis). Widgets download seems to work fine on stock. Any help would be great, thanks.
fatboy97
4,820
891
Just a guess, but since the Tbolt is not recognized by HTC running the Stock Froyo ROM, it's not going to recognize the Tbolt running a custom ROM... like I said, just a guess... I have not found a custom ROM that does work yet.
watson387
132
12
Yep. Same reason the Verizon apps don't work on custom ROMs.
fatboy97
4,820
891
I'd probably have to disagree with this since the MyVerizon app does work on the stock ROM, or it did a while ago... are you saying it does not work now??? And the MyVerizon app has worked with a couple ROMs, even though it just stopped working on Gingeritis 3D VIII after working for a while after I loaded it.
watson387
132
12
It doesn't work with AOSP ROMs as far as I can tell. I really wish it did though. I'd like to have a working Data Usage Widget on Liquid Thunderbread...
omarkarsly
