Problem in Unlocking Note 8 While Multi-tasking Feature is Active
remarbarquilla
4
Hey #Note8 users, are you having delayed in unlocking your phone while multi-task feature is active?
This is currently what I'm experiencing with this device :mad::mad::mad::mad::mad:
Note: Make sure to disable the "on display" feature and enable the biometric sensor.
Use split screen. (Use SMS pre-installed app by Samsung place it on top of the split screen and on the bottom use any document application [Excel, Word Doc, Samsung Note app] or Use gmail app.
Type anything on document application [Excel, Word Doc, Samsung Note app] or Use gmail app.
Make sure the keypad is active on the doc app or gmail app, then push the physical lock button to lock.
Place your finger to the biometric sensor and there you will experience the delayed in unlocking the phone. it takes several seconds to minute before the phone totally unlock and when it unlocks you will noticed the keypad delayed.
Then repeat in all doc apps and other apps.
Do you think this is a hardware defect or software bug? :confused::confused::confused::confused:
oguk
