Problem making calls on Kdkobes HoneyBread 3.0 ....HELP
Kimmy71
47
Have this Rom running for a few days w no problems then today when I go to make a call I get a force close box, then my service disappears for about 30 seconds then resets back to 4g. On an incoming call it will ring but when I go to answer it I get the same force close box. Could it be a radio issue or should I just flash another rom? Thanks...bit of a noob.
What radio are you using??? It's easy to load a new radio... I think the last one I loaded took 5-10 minutes before I full up and running.
If it's been working before I'm guessing it's not an issue with the radio... and I've been using 1.39.00.0629r Radio for a while without issue. You could load some other radio's if you want to check them out.
Did you reboot your device???
I did and it was still being wonky. I just flashed liquid gingersense...though I dont really like the look as much. We'll see what happens.
Ph4
