Problem Restarting phone!
alexbr91
Active member
Mar 23, 2010
33
Hey guys I have an issue with my phone. Its now running ICS. The problem is that when I try to restart or turn off my phone it gets stuck on the "goodbye!" screen. Its not a major flaw but its just annoying and I want to fix it! any suggestions!
Try doing a full data wipe. If it still does it then just get a replacement.
Sent From A Rotary Phone
I always dread doing a factory reset but I tried doing it but it wont let me click the "delete all". bummer I guess im calling tmobile for a replacement
Try this:
First, pull out the SD card, then try and format the USB storage, then follow my instructions in this thread (should be the third message)
http://forums.androidcentral.com/t-mobile-galaxy-s-ii/181031-how-do-factory-reset-ics.html#post1871655
That should get you to a good spot.
elvindavis
