Problem with ADW Launcher EX
Kwyjibo
4
Picked up the phone this morning at Best Buy with no problems, for everyone wondering they only had 4 in stock. So far the phone is awesome, but I wanted to switch the launcher to ADW since thats what I have been using on my Evo 4G for over a year now and I am used to it. For some reason, it won't let me set it as the default launcher, and every time I hit the home button it reverts back to Touchwiz. I've tried checking in app settings and it claims there are no defaults set for the launcher. Has anyone else had this problem trying to change the launcher or found a fix?
Are you sure u set ADW as default? Look for TwLauncher in all apps & see can you clear defaults from there. I just tried & have no problems
Thank you, that worked perfectly. Either I had accidentally set it as default, which I thought i checked, or touchwiz must be set as default from the start, instead of just being the only launcher as sense is on an HTC phone. Either way, working great now.
Glad you got it straightened out.
If any of us helped, feel free to hit the Thanks button! :D
jackhari2
