Problem with Asus Memopad
mansatuspn
My ASUS Memopad shows "No USB cable connected". and if I connect to my PC, it shows "Ready for Download". I can't get my bootloader. Please help me. :'(
Not exactly sure what model you have but most devices have a reset hole that you press with a paper clip, you can locate the hole and try a reset. This can cause loss of data so hopefully you have this backed up. On say the Smart 10 the reset hole is located under the microSD slot on the bottom left side, facing the screen.
Miserydhala
