Problem with contacts
agnellin
16
Hey I just got my Thunder Bolt yesterday and I love it!
The only problem I have is that it wont combine my facebook contacts and regular contacts...
Example: I have to John Smiths one is facebook contact and one is a google contact.
This is very annoying please help!
It should do it automatically, but to force the issue, you can go in and manually link the contacts. From a contact screen, tap the link button in the upper right corner (show here)
Then, simply tap the "All Contacts" button and select which contacts to link together.
Are you able to manually link the contacts? My contacts don't instantly link. My ThunderBolt seems to do it during times when the device is sleeping and then I'll see the notification later. What kind of time frame are you allowing?
Edit: also, are you using the Facebook app or the HTC Facebook app? If using the Facebook app, open the app and go to settings, scroll to the bottom and adjust there.
