Problem with download mode
McSullivan
Hello guys.
So I just flashed the russian Lollipop firmware that came out for the N900 into my device. I followed all the procedure to the letter (I am really cautious and it's not the first time I've flashed stuff); went to download mode, connected my Note to the cable, added the MD5 to Odin and started flashing. The procedure finished and the phone restarted, but I got a black screen after the "Samsung Galaxy Note 3" screen you get when you start the phone, but that wasn't really the problem since I read that a lot of people got that black screen and solved it by flashing the firmware again. My problem is when I go to download mode (power off the phone then volume down + power + home) I get the "Warning!!" confirmation screen, and then I press Volume up to continue, nothing happens!! Even when I press Volume down (which should get out of download mode and restart the device) nothing happens!
In case you're wondering, I can get with no problem into recovery mode.
Is there a way I can fix this and get into download mode? Maybe a way to get directly into download mode without the confirmation screen (I did read somewhere that holding volume up + volume down while turned off and then connecting the cable to the phone should get it directly into download mode, but that apparently doesn't work for me)
Help would be much appreciated, and sorry for the bad english.
Hello guys.
I'm having the same problem with that. I can't choose volume up or down. Did you have a solution already?
DonUAE
