problem with epic 4g cutting on
ryshawncul
10
has anybody been able to get there phone to cut back on after pulling usb cord out during odin i waited for 10 mins no movement with the blue line on dl screen so i figured i bricked has anyone ever got there phone back going afterwards
Try plugging the micro usb end of your data cable into your phone with the other end unplugged, then press and hold the 1 button (on physical keyboard) and the power button at the same time and hold while plugging the USB end into your pc. Yeah, I know you only have two hands but it's not like juggling or anything. lol. I believe this should "trick" the device back into download mode. There are threads out there addressing this very issue, if you did some more browsing you'd find more info but I believe this was the method that I had to use when I was in the same situation you are now. Good luck.
Reactions: ryshawncul
yes i did look for and answer the thing the other threads said to do didnt work but im back up and runnin had to turn it it for a new phone got it back lastr week but again thank you for your help
Mine has done that just about every time I used Odin at least once. I think what worked for me was pulling the battery and booting it into download mode while plugged into the computer. It's hard to remember because i was pretty much in a panic. :confused:
Twousay
