Problem with HDMI CEC when turning on
Timberwolf77
Hello,
When you turn off the TV box using the TV Box remote control, you can turn off the TV itself as well as turn it on, but only in the first 15 seconds until the TV box has completely turned off and is in “sleep mode” (I don’t know what to call it correctly).
To turn on the TV you have to use the TV remote, which is very inconvenient.
How can this problem be solved?
Is it possible to change something in the settings?
Maybe there is an app that can keep the device in the "sleeping mode" instead of shutting it down completely?
TV box (stick) - DQ06
Operating system - Android TV 12.00
ALLWinner H618
Welcome to Android Central! I moved this to the Android TV forum for more specific traffic.
Adekanmbi
