Problem With LauncherProPlus
kcinkiller1
14
I bought it and have the code, but when i click preferences i dont have the option to "unlock launcherproplus" and type in the code.
Try uninstalling the free version and reinstalling to fix. Also, check and see if you have the option for LP Widget settings after advanced settings. That's only difference between Pro and Plus. Maybe it updated itself. Now that I'm on Pro, the option to unlock is gone.
Reactions: kcinkiller1
Or if you have the free version and try to add a LauncherPro widget to a screen it will tell you that it's only available to LPP users and will give you the option to enter your key code.
Thanks to both of you for the input, fortuantley uninstalling then redownloading the latest version gave me the option to type in my code, thank you :)
