Problem with my battery
RandomDan
7
I have a weird problem.
I am running stock Froyo at the moment. My phone is doing some weird things when it comes to the battery. I swapped my batteries last night. I went to bed with a full battery. By the time I woke up, it was down to yellow. I swapped my battery out again for a full one, and a couple of hours later, it was down to around 50%. I tried plugging it in to recharge, and the led started flashing orange and green. I went to the battery status and level menu, and it said my battery was discharging rather than charging. I turned the phone off and tried recharging the phone that way. The orange led lit up when I plugged it in. I decided to reboot, and after rebooting, I checked my level again. It was over 80% after only charging for less than a minute. Does anybody have any ideas as to what might be going on and how to fix this?
Sounds like you had a zombie or out of control process. The shut down would have killed it. Did you install any new apps lately? That might be the culprit.
Falsey_Ga
