Problem with split screen
cybercreature
Hi all,
I've just updated my S6 software to Marshmallow and I'm trying to use the vertical split screen mode.
I go to recent apps, click the double icon on one of the apps to get the app in the top part of the screen.
The problem is that at this point the rest of the recent apps are not showing.
In all the tutorials I've looked at, once the first app is in the top part of the screen, the user can still see all the recent apps at the bottom of the screen, so that they can scroll through and choose one.
Anyone have any idea what the issue is?
Thanks a lot.
Also having the same problem. As soon. As soon as I updated to Marshmallow this problem started.
Hi all,
Thanks a lot.
I absolutely abhor this update because of this withdrawn feature. It's very difficult to go back unfortunately. Fix this People!
After you picked the 1st screen to show you can only tap on the icon showing in the bottom section. This does limit functionality somewhat. But it still works Screenshot_20160427-075435.jpg
mitiku Berihe
