Problem with the location-based weather widget on home screen
tourstagefan
Active member
Apr 20, 2010
26
I went on a road trip this weekend and now the phone only displays that particular region's weather and will not reset to where I am currently located.
I have tried refreshing as well as turning on/off the Location settings.
Any help would be greatly appreciated as I like this widget a lot.
Thank you.
hmmm only thing i can think of might be:
When you click on the weather widget it brings you to your desk clock
click on the weather, and it should bring you to the main weather screen
on this screen, make sure you are on current city, not locked onto a particular city.
you will see a "1/2" showing which city you are currently on, and how many you have total. in my case I have 2 and i'm on the first one. scroll up or down until you find the "city" (current city) and it should give your local weather
also check
hit menu >> settings
make sure update automatically is checked, and put update frequency to whatever you please
from home screen go to menu>settings>location. make sure "use wireless networks" is checked. Then under location settings, make sure "location on" is chosen.
vicinity
