problem with wifi widget
missouriexile
129
New member. had next. swapped for RAZR
because of. very bad signal problems.
just getting razr set up. u
I added the wifi on/off widget to my home screen. used it a couple of times.
then whatever app icon I pressed brought up the wifi screen.
had to power down and remove the widget to get app icons to work.
is this just me?
That's very odd. I have not had any issues with the toggle widgets.
Are you using the widget that came with the phone or one you downloaded?
Sent from my DROID RAZR using Tapatalk
