problem
suicidalerik
59
when i try to download an app on the play store it says "Error - Error processing purchase. [DF-BPA-09]" I Dont Know why it says that
Does it do that for every app? That only happens to me when I try to download, for example, a hdpi theme on ICS. even then it doesnt happen all of the time.
Clear Google framework cache
And uninstall market updates and let it re update
This should fix it
If what jonny said doesn't work reboot in to recovery and wipe cache and dalvik cache and reboot and wipe cache for market and force stop market then it should work
Sent from my LG-VM670 using Xparent SkyBlue Tapatalk 2
No. all you need to do is delete your google account and re-add it. then reboot and you'll be able to download apps. this used to happen to me all the time when I still my OV.
Reactions: sellers86
le_stan
