Problems Connecting LG G3 to Car's Navigation System (via microUSB)
seand31
Hi all,
Been struggling to find an answer to this, so hopefully you can all help. Here's kinda the run down:
Car: Mazda 3 2016 GS (Nav system with SD Card slot - used for the nav)
Phone: LG G3, running most updated software, extended 32GB SD card
Problem:
This is troubling. When I connect my phone via USB, it takes forever to load. I am not able to access my phone's contacts, messages, etc. In fact, it loads up the weirdest things - whatsapp voice notes, snapchat files, hidden files that can't be viewed amongst other things. It does not load up my music. This one is one I'm a bit worried about.
A second problem. When I connect my phone via Bluetooth, everything is okay... however, the system is unable to view the content of my music. It can't see the folders, playlists, etc. So a message pops up saying that. Is there something I can do on my phone to avoid this? Real pain not being able to navigate my music.
I do have a ton of music on my phone. I recently deleted a ton of photos and am thinking of shortening my music... but this was a big feature on the car that I really wanted to play around with... so this sucks. Your help is much appreciated gang... thank you!
I have a very similar issue with my 2014 Mazda 3. I can pair the phone to the car. I can skip forward or backwards but I can't view the contents. I get the message "unable to view the contents of the connected device".
I was able to try a Samsung Galaxy S6 in my car and it worked while using the Samsung Music App but not the stock music app.
I would like a solution to this issue as well. I was going to look at getting the LG G5 but I might have to switch to Samsung to get this feature.
cany
