Problems with bluetooth media audio
jharo
379
16
I'm having problems playing music over bluetooth to my LG HBS-250. I'm able to connect and make phone calls, but I can't get Slacker or the media player to play over bluetooth. Anyone have an idea?
Try,
menu
settings
wireless and networks
bluetooth settings
Then longhold on your device, listed under "bluetooth devices"
Options
Make sure under profiles "media" is checked
Thanks, I tried that. I might try an old BlackBerry trick...battery pull.
Ok, so after a battery pull, I now lost the option for media audio. Damn!
BTW, I fixed this problem. I had to uncheck the media audio option, then recheck it.
Try,
menu
settings
bluetooth settings
Options
Just tried this, and I don't have "media' listed under options. Only Connect and Phone.
wondr
