problems with pdanet
boos1906
48
Hey guys I just downloaded this app. I can't get it to show up on my computer when I plugn my phone into the computer to drag it over onto my desktop. Any ideas what I'm doing wrong??? Thanks for the help
I had to dl a second file when I did it for my Blackberry...not sure if the android version is any different. Check the instructions again
Did you DL the software to the computer that you want to use?
Its been awhile since I installed it (january) but I recall needing to install software from the website onto the computer that I wanted to link to. Once that is done you will have a lower left taskbar link for it on your computer.
EDIT:
The software you need installed on your computer is here:
http://www.junefabrics.com/android/
Noob
