Problems with RUU and unroot?
conski
147
6
Im not having the normal problem of getting errors like ive read in the sticky, it just gets me to "waiting for bootloader" and never goes further then that... ive been waiing for a half hour or so..
Anyone have this same problem who has used this before?
Which RUU from that last should i be using?
The most current for your phone. Sounds like it got stuck. You might have to start over. It can be a pain. Probably won't work the first try.
ive done it so many times! it always gets stuck right there?
i dont quite understand the other unroot in tht sitcky either
Are you planning on rooting afterwards or did you want to just unroot and stay unrooted?
i got pretty wasted in NYC and dropped it :/ my new one comes in the mail tomorrow so im unrooting this one and sending it back.
i plan on rooting again
I'd just send it back rooted.They aren't going to check for root.Plus you would already have your new phone.Rooting didn't break the phone dropping it did.
Does the phone even turn on? If not don't worry about it. If so they won't check for it because you filed the claim for damage.
this was said before in my former thread.. couple people said i should still unroot it.
the phone works great, its really just the screen looks like its got spider webs all over it from the huge amount of cracks
oh that was you in that thread. sorry i didn't realize. if you feel like giving up you can just break it so it doesn't turn on. easiest way would probably be to bend the contacts where the battery goes.
CHeck your PM box in just a min. going to send you something;)
you can try redownloading everything (maybe you have a corrupt file). and make sure you download from the links provided. they are proven to work. and other version of HTC sync might not work because they may have changed something. what method did you use to root originally?
Well somehow got it past bootloader phase.. im at 0% of erasing user data after about 3 minurw
I'm the one that said unroot in the other thread. Just saying because its real easy, grab the 3.29 ruu.
anaekeuwaemmanuel158
