Problems with Samsung Galaxy S6.
microserfs
17
Hey there,
I'm wondering if there may be a problem with my Samsung Galaxy S6 and I wanted to get some opinions before I try one last thing and fully reset it.
I've had the phone since April last year and for some reason the battery life has never really been good anyway. This isn't the main reason I am posting though as only recently I noticed a different issue when I tried to transfer some files onto the phone.
I was trying to use the cable that comes with the phone to charge it, and I've done so before when I've transferred files before from my Macbook. However, that time before I also found it very difficult to detect the phone and kept having to unplug it and plug it back in before it would see it. I was using the software Android File Transfer. Last night I could literally not get it to see my phone whatsoever... I plugged it into the computer and it would charge but it literally could not detect a connected device.
So here's where it gets frustrating as I spent the next two hours trying to fix this issue. I tried searching for a solution online which is why I'm now here after everything as all that I tried didn't work. I tried switching to SmartSwitch (and uninstalled AFT first), but that program also didn't detect my phone. Then I tried Airdroid, which worked only when I used the file upload under the browser but refused to connect to the phone when I clicked it on My Devices.
I even tried the method of *#0808# but it was actually already set to the correct settings so now I'm completely at a loss as to what it could be.
I've previously also had issues where I've plugged in the phone and it hasn't started fast charging and I haven't realised for an hour that it's only been cable charging and had to plug it back in for it to recognise it... is this likely a problem with the phone or cable?
I mean, aside from the also frustrating battery issues which have been worsening as time goes by (currently phone is on 79% having only used 39m screen time), I'm not sure whether it's time to give the phone a reset before actually taking it in to the store or whether it's likely an issue with the connector port at the bottom too which means it's probably not worth the hassle of resetting?
I won't go too much into the battery issues here, but I've been trying to use Greenify, App Optimisation, literally EVERYTHING I can think of, and I still don't get any more than 4 hrs and a half screen time.
My phone is not rooted. (though I'm wondering whether rooting it may help me). Thanks and I hope you have some advice that may resolve my issues!
Yeah but that's the maximum I've EVER got, and I mean my average is about 3 and a half hours..
but yeah, the other issues are kind of annoying too.
My friends with the Gs6 ,Tell me they average around 3 Hours Ost , So i think that about average bro , about the other issues try to get a new cable maybe that should fix the charging issue ,Good luck bro
You could try turning USB debugging on, if you don't already have it on. Maybe a factory reset or a different cable would work, too.
It already is on, and I tried a different cable too. The only other option is a factory reset and I'm not sure that'll work considering the amount of complaints there have been regarding it.
