problems with slacker radio on the tb
twistedjustice81285
48
I'm having a big problem with slacker radio on the tb. It constantly freezes when trying to advance tracks and will eventually force close. Is anyone else having this problem?
Yikes, I only used it for about 10 minutes to test with, but I didn't experience this.
Not sure if you noticed but there is a new setting in slacker that lets you stream higher quality music over lte. Maybe turning that on and restarting the application could trick it into working.
Yeah slacker has some issues on the tb. It's usable, but i get force closes and crap all the time. I had to download advanced task killer just to kill slacker when it messes up
Sent from my ADR6400L using Tapatalk
Yeah I was able to hear about 4 songs in a row and then it froze. One of the tracks didn't load all the way.
I'm having Slacker issues too. Cached station won't play and I get freezes and force closes.
Hope It's fixed soon!
I've been using it a fair amount without any problems. Mostly WiFi or 3G, if that makes a difference.
It does but slacker takes forever to come out with updates. Half the time they just make it worse. It took 3 different updates to work properly on the Droid incredible.
I had the same problems with slacker radio. I end up uninstalling the app and clearing app data then reinstall the update in the market and logged back in and it worked for me.
Reactions: Chrisy
Funny, I don't seem to have most of the problems mentioned in these forums including this one with Slacker radio. I must be lucky with phones as I also had the least amount of problems with my Fascinate last year.
Maybe it needs to be updated to work on our phones.
But it's working fine on some people's ThunderBolts so maybe there's some kind of conflict with another one of your apps or one of your settings?
EDIT: A bunch of app updates were available for me on the Android Market today. After updating them all, I got a notification that an update for Slacker was skipped so I went and found it and updated it as well. After doing so, Slacker stopped working for me with this error message:
! Tuning Error
Error Code: 404
org.apache.http.message.
BasicHttpResponse@479155a8
I uninstalled the software update, signed on again, still didn't work. So I uninstalled the software update again and cleared my data, and cleared my cache. After doing that I was able to use Slacker again. Until I cached a station again. And now I get the same error, first when I tried play a cached station and now also on other of my old favorite stations that are still available to me under 'recently played'. Don't seem to have any problems with the standard stations.
Anyway, wish I'd never installed that update. I can't remember if Slacker came pre-installed on my Thunderbolt, I think it did, but whichever version I had before worked fine. No problems, until I installed the update from the Android Market.
Reactions: Chrisy
yup i had issues with it too. it kept freezing and then would stop playing. the active icon on top would disappear. when i tried to open teh app it would just be a black screen. and 5-10 mins later i would get a force close/wait option.
! Tuning Error
Error Code: 404
Mine isn't locking up at all. I just can't play cached stations.
Slacker tweeted that they are up & running again and it's working perfectly again on my ThunderBolt, cached channels & all. Sorry it's not working for you, but maybe try uninstalling any updates, clearing cache, etc, and trying again.
Thanks, Robrecht
Reactions: Chrisy
MightyExecutor
