Problems with streamin radio apps
hal1
1,269
8
I tried the Galaxy Nexus when it first came out, then returned it. The streaming radio apps I used, Resco and TuneIn Radio, Radio.com., played for a 30 seconds then cut off.
Does anyone know if this was a problem with the radio, the software, of maybe the apps not being written to work with 4.0?
Has anyone had similar problems, or found it fixed with the updates?
I don't use any of those apps, but I am able to use Pandora and frequently stream music from my Amazon and Google Music accounts without any problem. If you don't find the answers you are looking for hear, you might have some luck contacting the App developers.
Steve in CT
May have been your specific device. I am an avid Tunein Radio user and have never had a problem using it on my GN, and I have had my GN since the release day. I use Tunein a minimum of daily.
racoo
