Problems with wifi tether
kevincwelch
582
47
I am using the wifi tether app (google project) and like a fool, I quickly dismissed some warning on the prime about not supporting ad hoc wifi networks.
I simply cannot get my prime to connect to my nexus s 4g using the wifi tether. The prime's wifi works fine. My laptop can connect to my phone when tethering.
Recommendations? Other programs?
What exactly are you trying to do? Are you trying to use your phones data connection on your Prime? If so, I connected to my phone VIA Bluetooth and used my phone's data connection that way.
Interesting.
I'll give the bluetooth a try.
But, yes, basically I am trying to use my phone's data connection on the prime.
There are obviously situations in which I would deem this necessary.
Interesting.
Going through Bluetooth gave me good results. Didn't try and do anything like stream, but, it was definitely working. It should be set to do this by default on your Prime just by connecting them.
Not sure if this other method you are talking about would yield faster speeds, but, I know for sure this one works, and, it's seamless. Just connect VIA Bluetooth and it should give you results right away. I was really impressed/pleased. I generally use my Prime where WiFi is available, so, I haven't really tested out the speeds. But, in a pinch, knowing I could go out through my phone is great. :D
Going through Bluetooth gave me good results. Didn't try and do anything like stream, but, it was definitely working. It should be set to do this by default on your Prime just by connecting them....Just connect VIA Bluetooth and it should give you results right away. I was really impressed/pleased.
Good to know.
I was able to connect my Nexus S 4G to my Prime via Bluetooth and they paired with each other, but I couldn't get it to stream data to the Prime. Both had internet function checked off.
Will have to play further with it.
Good to know.
Try rebooting both your phone and your Prime, then giving it another shot, if you don't have luck with that, respond to this and I'll mess with it in the morning. Maybe there was something I left out, but, I don't think there was.
Still a no go.
In fact, when both are connected via bluetooth, the popup control panel on the prime specifically states next to the bluetooth icon that there is no internet connection available. That may be unrelated, but I just can't get the bluetooth internet to work.
I can transfer back and forth via bluetooth...just no internet.
I think wifi tether will have to suffice.
When you said they both had internet function checked off before, did you mean it was off, or, it was checked to be on? I just wanna make sure you drilled into the connection on your Prime and made sure it was set for internet. I'll try and mess with it later, see if I can figure anything out. No time now.
Sorry re: the confusion. The checkbox is checked in both circumstances.
Man, that's really strange. Like I said, I didn't do anything special and it's working fine. I'm connected via Bluetooth right now, wireless is off, and, I'm responding to you. So, it's definitely working. Wish I had more advice for you. The only thing I can say is to reboot both devices a couple of times, and, maybe it'll work. And, if you are feeling up to it, the only other thing I can think of is a factory reset. Others have had problems with their Primes when they first got them and a reset fixed them. Other than that, I got nothing.
marksains61
