Proximity sensor problem VZW
pmaisonet
71
So I'm assuming I'm not the only one having proximity issues with my Note 3. I love the phone otherwise. But doea anyone know how Verizon will fix or address this issue? This happen to anyone else? Thanks
Sent from my SM-N900V using AC Forums mobile app
Verizon should replace the phone under warranty.
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
Do a search in this forum.. There's a huge thread on it
tap it on the table near top of the phone it is a loose sensor mine did that.... also download the sensor tester and you can see when it works and when it does not work. it took me 45 min to convince the tech that it was a loose connection
francomattia
