- Nov 17, 2013
- 232
- 0
- 0
Best Buy. I happened to notice it there when I picked up a Tab 3 8.0 for my daughter for Christmas. I conned the AT&T rep out of the spare one on the left. 3 should do me.
How much was it all together for the charger and the extra battery?
Sent from my T-Mobile Note 3 using AC Forums.
$49.99 plus tax.
That ain't bad at all.
I guess that's good, but do you really have problems with battery life on the Note 3? Mine is incredible compared to past devices I owned. Right now, I've been on battery for a bit over 31 hours (about 3.5 hours with the screen on) and still have nearly 40% power remaining. I could never get over 1 day of battery life on my other devices. As great as the Note 3 is overall, I have to say that I remain impressed by the battery life. But perhaps I'm a relatively light user compared to you or some other people. Heavier usage would likely drain the battery faster.
He may just want to be able to swap the batteries when needed so he never has to charge. Some like that.
Also sounds like you aren't a heavy user. On the weekends I can stretch my battery far since I don't use it as much but.... At work I let people tether off of me.. Use my phone to stream a lot of data.. And have the screen on alot (with low brightness.. Like 30%) and I can kill it before the end of my day (work shift.. Normal 8hours / 1 hour lunch).
So just depends on usage. His may be more so him swapping the battery may be what works best for him.
