[Q] Can I flash a SM-G925F firmware onto my AT&T edge?
mcagrigoktas
12
I bought s6 edge AT&T from USA but I am going to use my phone on europe.
G925A does not contain my country language.
I want to flash G925f on my AT&T s6 edge. Can I do this. What are the expected problems?
AT&T firmware is not available like other providers so you'd be lucky to find it. As the firmware is effectively locked, it's probably the last thing you would want to do. You should only flash firmware specific to the device otherwise you will end up with an expensive paperweight
What about T-mobile?
Tokopi21
