Qi Charger or Battery Pack?
ShAdoWSKy
Active member
Sep 10, 2010
40
If you guys had to choose one, would you invest into a Qi wireless charger? or an external-portable battery pack?
That really depends on who you are and what you want. I prefer the wireless charging
Sent from my Nexus 5
It also depends on your usage pattern. Are you using it a lot when away from home? If so, then an external battery pack makes more sense.
They're made for different things. It's not really an either/or situation.
Does wireless charging have any negative effects on the battery? Also I've read that wireless charging is slower than wired charging and also overheats your phone more easily.
I haven't noticed any negative effects, only positive for me. I don't find that it charges the phone that much slower, and if it does then its not a huge big deal to me. I also don't find my phone being any more overly hot then normal or when using the chord, but that's of course just my opinion.
