Qi charging drains battery
Rob Taylor
13
When charging wireless, my battery drains rather quickly instead of charging. I've tried 2 different charging stickers and 4 different charging mats.
Hmm looks like an app or apps running in the background might be the cause. I would try to check to see if thats the cause first. You can check by looking at battery usage under settings.
If it's an app causing this how can someone find out? Just curious if I run into this
Go to settings, battery and power saving, and select battery usage. It will show how much battery your apps are using. Screen will usually be first on the list but occasionally an app goes whack and you will see it high up on the list.
I'm using the LG OEM wireless charging back with the TYLT VU and everything is working fine.
Does the phone indicate wireless charging when first placing it on the charger?
Mine did that when I badly installed the sticker on to the original case. Now that I have the pricey oem case no problems.
It does indicate wireless charging when I put it on the mat. I even double checked the alignment of the contacts. Everything looks correct.
saujanya
