Question About the Fingerprint Scanner/Power Button....
jorajatt
7
I just recently bough my Atrix (7 days to be exact) and I had some questions/concers about the fingerprint scanner.
Is the power button supposed to be a little loose? Like when I slightly touch it, it moves inward a little.
How do I get dust particles out from under the power button?
These are pretty silly questions, but I'm just a little concerned.
on my atrix, if i slightly touch the power button, it does go inward slightly. i do believe that is normal.
as for the small dust particles, i see one or two but it doesnt bug me. as i hardly look at it. perhaps, using a compress air can get the dust particle out.
Thank you! I'll try that.
One more quick question, is the battery door supposed to be squeeqy or is it just mine?
Squeeky is relative. If you can barely tell and you can live with it, then just do so. If it bothers you, then have it exchanged right away while you can do so without having to claim warranty or insurance.
Any moving part is bound to attract dust during normal operation. Blowing on it, or compressed air seems to work. Or I just ignore most small dust particles.
What annoys me is actually built-up finger grime. I like to clean that out every now and then.
mine is kinda like that i thik thats how its supposed to be but i have no problems at all with it
Mine feels a tad loose as well, and yes I got dust particles in there ... Can of air does work well.
BobCat6767
